WLC 5508 - 7.5.102.0 - Wildcard Certificates
Does this controller/firmware support the use of a wildcard certificate? I'm using GoDaddy as our public CA.
1 ACCEPTED SOLUTION
Re: WLC 5508 - 7.5.102.0 - Wildcard Certificates
Yes, it does support.
You may visit the below listed URL while generating the CSR or installing the certificates.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00806e367a.shtml
~BR
Jatin Katyal
**Do rate helpful posts**
~BR Jatin Katyal **Do rate helpful posts**
Yes
Yes, controller/firmware support the use of a wildcard certificates.
You can also refer the link which states the same- https://supportforums.cisco.com/thread/2067781
~BR
Jatin Katyal
Hall of Fame Super Silver
Well I think we have to be a little clear:)
For WebAuth, wildcard does work, but I don't think it's supported if your trying to replace the management certificate for the GUI login.... Unless that has changed.
-Scott
716
