Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
WLC 5508 CPU ACL
Hi, how are you?.  Sorry  by my questions and thanks for the patience.
I have a doubt. CPU ACL affects only the traffic of the management interface?.
For example:
Controller WLC 5508 version 7.0.98.0
Interface management IP address 186.108.26.2/24
Interface XX IP address 190.139.109.101
I have configured the following ACL and applied to CPU ACL:
(Cisco Controller) >
(Cisco Controller) >show acl cpu
CPU Acl Name................................ ACL
Wireless Traffic............................ Enabled
Wired Traffic............................... Enabled
(Cisco Controller) >show acl summary
ACL Counter Status               Enabled
ACL Name                         Applied
ACL                              Yes
(Cisco Controller) >show acl detailed ACL
                       Source                        Destination                Source Port  Dest Port
Index  Dir       IP Address/Netmask              IP Address/Netmask        Prot    Range       Range    DSCP  Action      Counter
     1  In         1.1.1.0/255.255.255.0         1.1.1.115/255.255.255.255    6     0-65535   443-443    Any Permit           0
     2 Any         0.0.0.0/0.0.0.0         100.100.100.100/255.255.255.255    6    0-65535   443-443    Any Permit           0
     3 Any         0.0.0.0/0.0.0.0                 0.0.0.0/0.0.0.0          Any     0-65535     0-65535  Any   Deny          51
DenyCounter : 27
I have the following doubts
It is not necessary to allow the ports of tunnel capwap?.
I have applied this ACL and traffic from Interface XX to 190.139.109.101 is filter.  If I remove CPU ACL traffic to interface XX is permit.  Then CPU ACL affect all interfaces???.
1 REPLY
Re: WLC 5508 CPU ACL
better a late reply than no reply at all ...
The CPU ACL actually filters traffic that is destined to one of the WLC ip addresses, so it works on all interfaces, but does not filter all types of traffic. Only traffic that is destined to the WLC itself.
So if you apply a CPU ACL, it is likely you need to either allow capwap ports or allow everything in the subnet where APs are.
Nicolas
2440
