01-10-2012 03:05 AM - edited 07-03-2021 09:21 PM
We have two wlc in the system 5508 and 4402.
we config HA for 2 wlc, both wlc enable LAG
When I connect 2 interface of 5508 to 2 interface (in a port channel mode on, trunk, dot1q) of a
couple of VSS switch, I cant management 5508 through web any more, and I still can do with 4402.
If I shutdown 1 port int the port-channel, it work well.
Do you know what happen ?
Duyen
01-10-2012 04:24 AM
Double check your etherchannel configuration on your switch and make sure you applied it to the correct ports. The two WLC's are on different port channels correct? Can you post your interface configuration and the cdp.
Scott Fella
Sent from my iPhone
01-10-2012 09:20 AM
hi Scott,
We have VSS ( 2 x 6509) trunk with (2 switch 4506). one port of wlc4402 connect to one port of one swith 4506.
2 ports of wlc 5508 conect to 6509, each port connect to one switch 6509.
the config in VSS switch like this:
interface gig1/1/1
switchport mode trunk
channel-group 500 mode on
interface gig2/1/1
etherchannel load-balancer src-dst-ip
( I dont see this command in running config)
01-10-2012 09:32 AM
Okay so the wlc4402 is on a different channel group than the wlc5508 correct? If you do a show etherchannel load-balance, you will see the algorithm that it's using. Do you have the management interface tag for a vlan or is it set to "0". If it is set to "0" then you new to specify the native vlan on the trunk port. What is the channel group on the wlc4402?
Scott Fella
Sent from my iPhone
01-10-2012 04:39 PM
we have a management vlan for both wlc (vlan 99). wlc4402 only trunk to sw 4506 by one port.
btw, I have test HA, when wlc5508 down, APs will join 4402 after 30s -> 60s and fallback to wlc5508 when 5508 online.
Duyen.
01-10-2012 07:29 PM
Looking at the switch port configuration, you will need to ensure that LAG is enabled on the Management interface for the 5508 and that the VLAN Tag is set to 99
Also on the VSS check that the Interface PortChannel 500 is enabled and has the same configuration as the switch ports. (minus the "channel-group 500 mode on" command)
Darren
01-10-2012 07:44 PM
Can you post the show run-config and the switch configs? That may help us better see what is going on
01-10-2012 10:10 PM
which portion you want to know ?
interface config above, we config int vlan in VSS, Microsoft DHCP.
01-10-2012 10:20 PM
LAG enable, both interface g1/1/1 and G2/1/1 is L2 int.
01-10-2012 10:49 PM
when you create a port channel with physical interfaces a virtual port channel interface is created using the same Channel Group ID.
can you post the config for the Port Channel Interface. Also, can you post the output of the following command
show interface port500
Darren
01-10-2012 08:17 PM
Is LAG enabled on the 5508?
01-10-2012 10:06 PM
Iam sure about this.
