WLC 5508 WPA Authentication Problems
We have a WLC 5508 with 7.4.100.0 Firmware.
We are using 1141 and 1142 APs and we are having authentication problems with clients that are connecting to our WLAN with WPA+AES autentication. The clients receive in her laptop a password error, and we receive the following log in wlc:
Client Excluded: MACAddress:f8:f1:eb:dd:ff:cd Base Radio MAC :08:ad:dd:76:4d:30 Slot: 0 User Name: unknown Ip Address: unknown Reason:802.1x Authentication failed 3 times. ReasonCode: 4
The strange thing is that the problem is solved restarting the Access-points.
Anyone had this problem previusly?
Thanks in advance.
  • Security and Network Management
Everyone's tags (4)
1 ACCEPTED SOLUTION
Hi, Dont be confused, dot1x
Dont be confused, dot1x is the security frame work as well for 802.1X. While you are using PSK and NOT 802.1X security it will show dot1x.
In fact the 4 way handshake is the same as well.
Based on what you show and the comments already made. When you have issues like this its always best to pull away the complexity.
I agree, dont mix security user one or the other. Client can be confused at times when they see both IEs in the management frames.
I would also do a client debug and try and catch a client in the act of misbehaving. If you do, post it.
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
Use WPA/TKIP or WPA2/AES.
Use WPA/TKIP or WPA2/AES.  Best not to mix & match.
I made the configuration
I made the configuration using the Cisco Recommended settings, the strange thing its that the users connect normally, until they starts with authentication problems. I restart the access points and the problem its solved.
Cisco Recommended  and not recommended Authentication Settings
Security encryption settings need to be identical for WPA and WPA2 for TKIP and AES as shown in this image:
These images provide examples of incompatible settings for TKIP and AES:
Note: Be aware that security settings permit unsupported features.
These images provide examples of compatible settings:
do you use PSK ? for the WLAN
do you use PSK ? for the WLAN or dot1x?
and is disabling the WLAN and enable it again solve the issue ?
Hello, we are using PSK, but
Hello, we are using PSK, but we didnt try to disable and enable the WLAN, do you think its good idea?
yes as we can see a
yes as we can see a misbehaving that the traplog show us that the client is fail the dot1x while the WLAN is not configured with dot1x
Yes, the error says dot1x but
Yes, the error says dot1x but in our config we have selected in L2 Security WPA.WPA2
Its stange
And 802.1x its disabled
Please provide a screen shot
Please provide a screen shot of your WLAN security configuration.
Remember, use only WPA/TKIP OR WPA2/AES on a particular WLAN, not both.
664
