Community Member
WLC 7.6.100 traps
Hello Guyz,
I have recently upgraded to WLC 7.6.100 on WLC5508 and i am receiving the following trap messages often.
Cause=Indicates that while the radio state should be updated on controller, no reset should be reported. Status:NA
Any idea what would be the cause?
thanks in advance.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Might be an issue with the
Might be an issue with the code... that version wasn't great.  There is a new version which ifxes some major bugs.... v7.6.110.0.... this is what you should upgrade to.
-Scott
1 REPLY
-Scott
233
