WLC 7 on 5508 - 802.1x and Local Net Users or LDAP
Is it possible under the 7 version of the software to use LDAP or Local Net Users for authentication instead of RADIUS for doing 802.1x authentication, and if it is, is there any documentation around that has some configuration information?  I've been doing some poking around and haven't had much luck yet.
Hall of Fame Super Gold
Re: WLC 7 on 5508 - 802.1x and Local Net Users or LDAP
Wireless users on 802.1x?  We're in the midst of testing this with 6.X and 7.X firmware.  So far, no complaints.
I assume you're using RADIUS as the backend for that?  If so, in this case I'm trying to avoid using RADIUS if possible.
592
