Community Member
WLC and jamming sygnals
Is it possible to configure on the WLC jamming radio signals from other AP's?
Kamil
1 REPLY
Hall of Fame Super Blue
Re: WLC and jamming sygnals
"jam" has a very baaaaaad connotation. It is called "contain" and yes.  It can be done.  I'd recommend you make sure the Rogue AP is inside your premises before taking it further.  Also, check the local regulation guidelines as containing a rogue AP within the confines of your premises is punishable by law.
215
