WLC and Radius Packet of Disconnect
How do the wireless lan controllers (in my case a 4402 running 4.1.171.0) support RFC 3576? I'm try to send a disconnect packet from my Radius server to the WLC and its rejecting it as an unknown;
(Cisco Controller) >show radius summary
Vendor Id Backward Compatibility................. Enabled
Credentials Caching.............................. Disabled
Call Station Id Type............................. IP Address
Aggressive Failover.............................. Enabled
Keywrap.......................................... Disabled
Authentication Servers
Idx Type Server Address Port State Tout RFC3576 IPSec - AuthMode/Phase1/Group/Lifetime/Auth/Encr
1 NM 10.1.1.2 1645 Enabled 2 Enabled Disabled - none/unknown/group-0/0 none/none
Accounting Servers
1 N 10.1.1.2 1646 Enabled 2 N/A Disabled - none/unknown/group-0/0 none/none
(Cisco Controller) >debug aaa all enable
(Cisco Controller) >Fri Jul 6 16:18:16 2007: Received a 'RFC-3576 Disconnect-Request' from unknown server 10.1.1.2:50844
Fri Jul 6 16:18:19 2007: Received a 'RFC-3576 Disconnect-Request' from unknown server 10.1.1.2:50844
Fri Jul 6 16:18:22 2007: Received a 'RFC-3576 Disconnect-Request' from unknown server 10.1.1.2:50844
Re: WLC and Radius Packet of Disconnect
Probably you have figured this out by now, but the packet probably has to be sent from the same port as normal RADIUS traffic -- you are sending it from port 50844. The WiSM thinks your radius server is at port 1645.
J - did you ever find a solution to this issue of the unknown server. I am seeing the same problem at the moment myself and was wondering if anyone has solved it? Cheers Cam.
WLC AAA Debug message:
Fri May 9 14:37:01 2008: Received a 'RFC-3576 Disconnect-Request'
from
unknown server 172.16.1.62:32769
810
