WLC Called station ID Issue
Hi All,
I have a problem with accounting from WLC. Sometimes we receive accounting of  users using called station ID = controller MAC address instead of the configured called station ID on controller “AP name : SSID” knowing that each user is connected form the same location . Please find below sample of accounting
Controller: WISM2 with image 7.4.100.0
User Name
NAS-IP
Framed IP address
Called Station ID
Calling Station ID
NAS ID
ACCTSTATUS TYPE
Input Octets
Output Octets
Acct session ID
Acct Session Time
Event Time Stamp
00127b38b496
10.94.70.2
84.233.48.235
90019-01:Etisalat_Hotspot
84.233.48.235
RMS-WLC1
Stop
821319
3166606
5320dd71/00:12:7b:38:b4:96/4007443
34200
Thu Mar 13 09:49:29 2014
00127b38b496
10.94.70.2
84.233.62.47
2c-54-2d-3a-31-20
84.233.62.47
RMS-WLC1
Stop
357141
7215694
5321b847/00:12:7b:38:b4:96/4057299
17445
Thu Mar 13 20:44:02 2014
Wait any feedback please .
VIP Purple
If you still running 7.4.100
If you still running 7.4.100.0, then please upgrade to 7.4.121.0 & then check.
Rasika
**** Pls rate all useful responses ****
Thanks for your feedback.
Thanks for your feedback. But please if i face the problem after upgrade, can we expect where is the problem.
VIP Purple
The version I mentioned is
The version I mentioned is supported by Cisco TAC, so at least you can log a TAC case & find the root cause in worst case scenario.
If this is a buggy  behaviour of your current code 7.4.100.0 (lot of chances it may be), then you will not see this in later version.
It is not worth to do lots of troubleshooting, knowing that software code is deferred by Cisco.
Rasika
Bronze
Hi,Yes, it seems bugs in this
Yes, it seems bugs in this code 7.4.100.0, its better you upgrade the latest version and then check, if problem exist then we will further rectify.. but most probably in will be fix in latest code.
130
