WLC - Cannot reach Management IP from LAN.
I have a 2811 (running 12.4(15)XZ) with a WLCM (4.2.209.0).
I have reset the configurations on both.
Set FE and WLCM IPs on the router and gave WLC Management and AP manager addresses.
All + PC are on the same subnet.
Router pings all addresses besides AP-manager(intended). WLC CLI cannot ping PC and PC cannot ping (nor http) to WLC. PC can however ping and telnet the router on both the FE and WLCM IPs.
I followed the guides on WLCM configuration, did I miss something?
How can I access the management IP and the web GUI?
2811 config:
Building configuration...
Current configuration : 1292 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret 5 $1$Cqw1$hEVpc7p4.l99WgLrettec.
enable password ********
dot11 syslog
no ip routing
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
no ip cef
no ipv6 cef
voice-card 0
no dspfarm
archive
log config
  hidekeys
interface FastEthernet0/0
no ip address
no ip route-cache
shutdown
duplex auto
speed auto
interface FastEthernet0/1
ip address 172.31.35.60 255.255.0.0
no ip route-cache
duplex full
speed auto
no mop enabled
interface Integrated-Service-Engine1/0
ip address 172.31.35.61 255.255.0.0
no ip route-cache
no keepalive
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line 66
no activation-character
no exec
transport preferred none
transport input all
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
password *******
login
scheduler allocate 20000 1000
end
WLC Config:
System Inventory
NAME: "Chassis"    , DESCR: "Cisco Wireless Controller"
PID: NME-AIR-WLC8-K9,  VID: V01,  SN: **************
Burned-in MAC Address............................ *******************
Press Enter to continue Or <Ctl Z> to abort
System Information
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 4.2.209.0
RTOS Version..................................... 4.2.209.0
Bootloader Version............................... 4.2.209.0
Build Type....................................... DATA + WPS
System Name...................................... Cisco_WLC
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.818
IP Address....................................... 172.31.35.62
System Up Time................................... 0 days 0 hrs 41 mins 50 secs
Configured Country............................... EE  - Estonia
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
3rd Party Access Point Support................... Disabled
Number of Active Clients......................... 0
--More-- or (q)uit
Switch Configuration
802.3x Flow Control Mode......................... Disable
Current LWAPP Transport Mode..................... Layer 3
LWAPP Transport Mode after next switch reboot.... Layer 3
FIPS prerequisite features....................... Disabled
Secret obfuscation............................... Enabled
Network Information
RF-Network Name............................. WLCM-Group
Web Mode.................................... Enable
Secure Web Mode............................. Enable
Secure Web Mode Cipher-Option High.......... Disable
Secure Web Mode Cipher-Option SSLv2......... Enable
Secure Shell (ssh).......................... Enable
Telnet...................................... Disable
Ethernet Multicast Mode..................... Disable   Mode: Mcast  0.0.0.0
Ethernet Broadcast Mode..................... Disable
IGMP snooping............................... Disabled
IGMP timeout................................ 60 seconds
User Idle Timeout........................... 300 seconds
ARP Idle Timeout............................ 300 seconds
ARP Unicast Mode............................ Disabled
Cisco AP Default Master..................... Disable
Mgmt Via Wireless Interface................. Disable
Mgmt Via Dynamic Interface.................. Disable
Bridge MAC filter Config.................... Enable
Bridge Security Mode........................ EAP
Over The Air Provisioning of AP's........... Disable
AP Fallback ................................ Enable
--More-- or (q)uit
Web Auth Redirect Ports .................... 80
Fast SSID Change ........................... Disabled
802.3 Bridging ............................. Disable
Port Summary
           STP   Admin   Physical   Physical   Link   Link
Pr  Type   Stat   Mode     Mode      Status   Status  Trap     POE
1  Normal  Forw Enable  Auto       1000 Full  Up     Enable  N/A
AP Summary
Number of APs.................................... 0
AP Name             Slots  AP Model             Ethernet MAC       Location          Port  Country
Cheers!
Hall of Fame Super Silver
Can you post the rest of the WLC config?
-Scott
Can you check the device connected to F0/1?  Make sure that you don't have a duplex mismatch
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
The FE0/1 has no duplex mismatch and the routers connection with the PC is ok over that link.
The bridge between PC-2811-WLCM is whats not working well :/
Not FE0/1, but what is connected to it, so the switch on the other end.
HTH,
Steve
Re: WLC - Cannot reach Management IP from LAN.
Steve, there is nothing but the PC and 2811 with the WLC module.
and the PC is configured to be 100/full?  or is it auto/auto?
HTH,
Steve
Windows 7, Auto Negotiation, 1000mbit interface. I really appreciate your help Steve
can you set the router to auto/auto and see if it will allow you to pass traffic?
HTH,
Steve
Sven,
I believe that the fast ethernet interface has to be on a separate IP subnet and the default gateway on the management interface in the WLCM points at the IP address on the ISE interface in the router.
Refer to config example below:
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a00807112e2.shtml
Bill Jenkins
Ok interesting info!
I have now tried with a different subnet (192.168.1.1/24 for FE0/1 and 192.168.1.2/24 pointing to 1 for PC).
Interestingly I cannot ping 192.168.1.1 from the router but everything remained same - PC pings router and WLCM but not WLC Management. Router pings everything. WLC pings FE0/1 and WLCM.
PC(192.168.1.2/24):
C:\Users\Svea>ping 192.168.1.1
Pinging 192.168.1.1 with 32 bytes of data:
Reply from 192.168.1.1: bytes=32 time=1001ms TTL=255
Reply from 192.168.1.1: bytes=32 time=1ms TTL=255
Ping statistics for 192.168.1.1:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 1ms, Maximum = 1001ms, Average = 251ms
C:\Users\Svea>ping 172.31.35.61
Pinging 172.31.35.61 with 32 bytes of data:
Reply from 172.31.35.61: bytes=32 time=1ms TTL=255
Ping statistics for 172.31.35.61:
    Minimum = 1ms, Maximum = 1ms, Average = 1ms
C:\Users\Svea>ping 172.31.35.62
Pinging 172.31.35.62 with 32 bytes of data:
Request timed out.
Ping statistics for 172.31.35.62:
    Packets: Sent = 1, Received = 0, Lost = 1 (100% loss),
Control-C
^C
C:\Users\Svea>tracert 172.31.35.61
Tracing route to 172.31.35.61 over a maximum of 30 hops
  1     1 ms     1 ms    <1 ms  172.31.35.61
Trace complete.
C:\Users\Svea>tracert 172.31.35.62
Tracing route to 172.31.35.62 over a maximum of 30 hops
  1     *        *        *     Request timed out.
  2     *        *        *     Request timed out.
  3     *        *        *     Request timed out.
  4  ^C
Thank you Bill for pointing out that the Management and AP Manager IPs should point to the WLCM ISE. Unfortunately it didn't change anything.
I am still open for suggestions but in a few days I will ship it to a live environment and see if that changes anything.
I will try setting the router from full duplex to auto (speed is auto atm) tomorrow. I doubt it has an effect because I have no problem reaching the router that contains the WLCM over IP.
Continuing......
AP Location
Status........................................... disabled
Press Enter to continue Or to abort
AP Config
AP Airewave Director Configuration
802.11A Configuration
802.11a Network.................................. Enabled
11nSupport....................................... Enabled
      802.11a Low Band........................... Enabled
      802.11a Mid Band........................... Enabled
      802.11a High Band.......................... Enabled
802.11a Operational Rates
    802.11a 6M Rate.............................. Mandatory
    802.11a 9M Rate.............................. Supported
    802.11a 12M Rate............................. Mandatory
    802.11a 18M Rate............................. Supported
    802.11a 24M Rate............................. Mandatory
    802.11a 36M Rate............................. Supported
    802.11a 48M Rate............................. Supported
    802.11a 54M Rate............................. Supported
802.11n MCS Settings:
    MCS 0........................................ Supported
    MCS 1........................................ Supported
    MCS 2........................................ Supported
    MCS 3........................................ Supported
    MCS 4........................................ Supported
    MCS 5........................................ Supported
    MCS 6........................................ Suppor--More-- or (q)uit
ted
    MCS 7........................................ Supported
    MCS 8........................................ Supported
    MCS 9........................................ Supported
    MCS 10....................................... Supported
    MCS 11....................................... Supported
    MCS 12....................................... Supported
    MCS 13....................................... Supported
    MCS 14....................................... Supported
    MCS 15....................................... Supported
802.11n Status:
    A-MPDU Tx:
        Priority 0............................... Enabled
        Priority 1............................... Disabled
        Priority 2............................... Disabled
        Priority 3............................... Disabled
        Priority 4............................... Disabled
        Priority 5............................... Disabled
        Priority 6............................... Disabled
        Priority 7............................... Disabled
    A-MSDU Tx ................................... Enabled
    Rifs Tx ..................................... Enabled
    Guard Interval .............................. Short
--More-- or (q)uit
Beacon Interval.................................. 100
CF Pollable mandatory............................ Disabled
CF Poll Request mandatory........................ Disabled
CFP Period....................................... 4
CFP Maximum Duration............................. 60
Default Channel.................................. 36
Default Tx Power Level........................... 1
DTPC  Status..................................... Enabled
DTIM Period...................................... 1
Fragmentation Threshold.......................... 2346
Long Retry Limit................................. 4
Maximum Rx Life Time............................. 512
Max Tx MSDU Life Time............................ 512
Medium Occupancy Limit........................... 100
Pico-Cell Status................................. Disabled
Pico-Cell-V2 Status.............................. Disabled
RTS Threshold.................................... 2347
Short Retry Limit................................ 7
TI Threshold..................................... -50
Traffic Stream Metrics Status.................... Disabled
Expedited BW Request Status...................... Disabled
EDCA profile type................................ default-wmm
Voice MAC optimization status.................... Disabled
--More-- or (q)uit
Call Admision Control (CAC) configuration
   Voice AC - Admission control (ACM)............ Disabled
   Voice max RF bandwidth........................ 75
   Voice reserved roaming bandwidth.............. 6
   Voice load-based CAC mode..................... Disabled
   Voice tspec inactivity timeout................ Disabled
   Video AC - Admission control (ACM)............ Disabled
   Voice Stream-Size............................. 84000
   Voice Max-Streams............................. 2
   Video max RF bandwidth........................ Infinite
   Video reserved roaming bandwidth.............. 0
802.11A Advanced Configuration
802.11A Airewave Director Configuration
RF Event and Performance Logging
  Channel Update Logging......................... Off
  Coverage Profile Logging....................... Off
  Foreign Profile Logging........................ Off
  Load Profile Logging........................... Off
  Noise Profile Logging.......................... Off
  Performance Profile Logging.................... Off
  TxPower Update Logging......................... Off
Default 802.11a AP performance profiles
  802.11a Global Interference threshold.......... 10 %
  802.11a Global noise threshold................. -70 dBm
  802.11a Global RF utilization threshold........ 80 %
  802.11a Global throughput threshold............ 1000000 bps
  802.11a Global clients threshold............... 12 clients
  802.11a Global coverage threshold.............. 16 dB
  802.11a Global coverage exception level........ 25 %
  802.11a Global client minimum exception lev.... 3 clients
Default 802.11a AP monitoring
  802.11a Monitor Mode........................... enable
  802.11a Monitor Channels....................... Country channels
  802.11a AP Coverage Interval................... 180 seconds
--More-- or (q)uit
  802.11a AP Load Interval....................... 60 seconds
  802.11a AP Noise Interval...................... 180 seconds
  802.11a AP Signal Strength Interval............ 60 seconds
Automatic Transmit Power Assignment
  Transmit Power Assignment Mode................. AUTO
  Transmit Power Update Interval................. 600 seconds
  Transmit Power Threshold....................... -70 dBm
  Transmit Power Neighbor Count.................. 3 APs
  Transmit Power Update Contribution............. SNI.
  Transmit Power Assignment Leader............... 00:1e:13:33:f2:60
  Last Run....................................... 87 seconds ago
Automatic Channel Assignment
  Channel Assignment Mode........................ AUTO
  Channel Update Interval........................ 600 seconds [startup]
  Anchor time (Hour of the day).................. 0
  Channel Update Contribution.................... SNI.
  Channel Assignment Leader...................... 00:1e:13:33:f2:60
  DCA Sensitivity Level: ...................... STARTUP (5 dB)
  Channel Energy Levels
    Minimum...................................... unknown
    Average...................................... unknown
--More-- or (q)uit
    Maximum...................................... unknown
  Channel Dwell Times
  Auto-RF Allowed Channel List................... 36,40,44,48,52,56,60,64
  Auto-RF Unused Channel List.................... 100,104,108,112,116,120,124,
    ............................................. 128,132,136,140
  DCA Outdoor AP option.......................... Disabled
Radio RF Grouping
  802.11a Group Mode............................. AUTO
  802.11a Group Update Interval.................. 600 seconds
  802.11a Group Leader........................... 00:1e:13:33:f2:60
    802.11a Group Member......................... 00:1e:13:33:f2:60
  802.11a Last Run............................... 87 seconds ago
Mobility Configuration
Symmetric Mobility Tunneling (current) .......... Disabled
Symmetric Mobility Tunneling (after reboot) ..... Disabled
Mobility Protocol Port........................... 16666
Default Mobility Domain.......................... WLCM-Group
Mobility Keepalive interval...................... 10
Mobility Keepalive count......................... 3
Mobility Group members configured................ 1
Controllers configured in the Mobility Group
MAC Address        IP Address       Group Name         Status
00:1e:13:33:f2:60    172.31.35.62     WLCM-Group       Up
Interface Configuration
Interface Name................................... ap-manager
MAC Address...................................... 00:1e:13:33:f2:60
IP Address....................................... 172.31.35.63
IP Netmask....................................... 255.255.0.0
IP Gateway....................................... 172.31.35.1
VLAN............................................. untagged
Physical Port.................................... 1
Primary DHCP Server.............................. 172.31.35.22
Secondary DHCP Server............................ Unconfigured
DHCP Option 82................................... Disabled
ACL.............................................. Unconfigured
AP Manager....................................... Yes
Guest Interface.................................. No
Interface Name................................... management
AP Manager....................................... No
Interface Name................................... virtual
IP Address....................................... 1.1.1.1
Virtual DNS Host Name............................ Disabled
WLAN Configuration
WLAN Identifier.................................. 1
Profile Name..................................... WLCM-Clients
Network Name (SSID).............................. WLCM-Clients
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 1800 seconds
Interface........................................ management
WLAN ACL......................................... unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Quality of Service............................... Silver (best effort)
Scan Defer Priority.............................. 5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability....--More-- or (q)uit
......... Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
IPv6 Support..................................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
Radius Servers
   Authentication................................ Global Servers
   Accounting.................................... Global Servers
Local EAP Authentication......................... Disabled
Security
   802.11 Authentication:........................ Open System
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Enabled
      WPA (SSN IE)............................... Disabled
      WPA2 (RSN IE).............................. Enabled
         TKIP Cipher............................. Disabled
         AES Cipher.............................. Enabled
      Auth Key Management
         802.1x.................................. Enabled
         PSK..................................... Disabled
--More-- or (q)uit
         CCKM.................................... Disabled
   CKIP ......................................... Disabled
   IP Security Passthru.......................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   H-REAP Local Switching........................ Disabled
   Infrastructure MFP protection................. Enabled (Global Infrastructure MFP Disabled)
   Client MFP.................................... Optional
   Tkip MIC Countermeasure Hold-down Timer....... 60
Mobility Anchor List
WLAN ID     IP Address            Status
ACL Configuration
CPU ACL Configuration
CPU Acl Name................................ NOT CONFIGURED
Wireless Traffic............................ Disabled
Wired Traffic............................... Disabled
RADIUS Configuration
Vendor Id Backward Compatibility................. Disabled
Call Station Id Type............................. IP Address
Aggressive Failover.............................. Enabled
Keywrap.......................................... Disabled
Authentication Servers
Idx  Type  Server Address    Port    State     Tout  RFC3576  IPSec - AuthMode/Phase1/Group/Lifetime/Auth/Encr
Accounting Servers
TACACS Configuration
Idx  Server Address    Port    State     Tout
Authorization Servers
Accounting Servers
LDAP Configuration
Local EAP Configuration
User credentials database search order:
    Primary ..................................... Local DB
Timer:
    Active timeout .............................. 300
Configured EAP profiles:
EAP Method configuration:
    EAP-FAST:
      Server key ................................
      TTL for the PAC ........................... 10
      Anonymous provision allowed ............... Yes
      Authority ID .............................. 436973636f0000000000000000000000
      Authority Information ..................... Cisco A-ID
Route  Info
Number of Routes................................. 0
Destination Network          Genmask               Gateway
ACL Configuration
Accounting Servers
Accounting Servers
LDAP Configuration
Timer:
    EAP-FAST:
Route  Info
Qos Queue Length Info
Platinum queue length............................ 100
Gold queue length................................  75
Silver queue length..............................  50
Bronze queue length..............................  25
Mac Filter Info
Authorization List
Authorize APs against AAA ....................... disabled
Allow APs with Self-Signed Certificate (SSC) .... disabled
Load Balancing Info
Aggressive Load Balancing........................ Disabled
Aggressive Load Balancing Window................. 5 clients
Dhcp Scope Info
Exclusion List ConfigurationUnable to retrieve exclusion-list entry
CDP Configuration
cdp.............................................. disabled
Country Channels Configuration
Configured Country............................. EE  - Estonia
      KEY: * = Channel is legal in this country and may be configured manually.
           A = Channel is the Auto-RF default in this country.
           . = Channel is not legal in this country.
           C = Channel has been configured for use by Auto-RF.
           x = Channel is available to be configured for use by Auto-RF.
         = Regulatory Domains allowed by this country.
802.11BG    :
Channels    :                   1 1 1 1 1
            : 1 2 3 4 5 6 7 8 9 0 1 2 3 4
EE (-E)    : A * * * * A * * * * A * * .
802.11A    :                         1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1
Channels    : 3 3 3 4 4 4 4 4 5 5 6 6 0 0 0 1 1 2 2 2 3 3 4 4 5 5 6 6
            : 4 6 8 0 2 4 6 8 2 6 0 4 0 4 8 2 6 0 4 8 2 6 0 9 3 7 1 5
EE (-E)    : . A . A . A . A A A A A * * * * * * * * * * * . . . . .
--More-- or (q)uit
WPS Configuration Summary
Auto-Immune
  Auto-Immune.................................... Disabled
Client Exclusion Policy
  Excessive 802.11-association failures.......... Enabled
  Excessive 802.11-authentication failures....... Enabled
  Excessive 802.1x-authentication................ Enabled
  IP-theft....................................... Enabled
  Excessive Web authentication failure........... Enabled
Trusted AP Policy
  Management Frame Protection.................... Disabled
  Mis-configured AP Action....................... Alarm Only
    Enforced encryption policy................... none
    Enforced preamble policy..................... none
    Enforced radio type policy................... none
    Validate SSID................................ Disabled
  Alert if Trusted AP is missing................. Disabled
  Trusted AP timeout............................. 120
--More-- or (q)uit
Untrusted AP Policy
  Rogue Location Discovery Protocol.............. Disabled
    RLDP Action.................................. Alarm Only
  Rogue APs
    Rogues AP advertising my SSID................ Alarm Only
    Detect and report Ad-Hoc Networks............ Enabled
  Rogue Clients
    Validate rogue clients against AAA........... Disabled
    Detect trusted clients on rogue APs.......... Alarm Only
  Rogue AP timeout............................... 1200
Signature Policy
  Signature Processing........................... Enabled
Custom Web Configuration
Radius Authentication Method..................... PAP
Cisco Logo....................................... Enabled
CustomLogo....................................... None
Custom Title..................................... None
Custom Message................................... None
Custom Redirect URL.............................. None
Web Authentication Type.......................... Internal Default
External Web Authentication URL.................. None
Configuration Per Profile:
Thanks for you time.
the whole thing now sits in the live environment:
  • Everything is pointing to the WAN gateway 172.31.35.1
  • With the exception of WLC whose Management and AP-Manager point to ISE-172.31.35.61
Problem: no connection (ping, web access) between Windows 7(PC) and WLC
2811 has no problem pinging either of those:
Router>ping 172.31.35.124
Sending 5, 100-byte ICMP Echos to 172.31.35.124, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
Router>ping 172.31.35.62
Sending 5, 100-byte ICMP Echos to 172.31.35.62, timeout is 2 seconds:
Current config of 2811:
Router>en
Password:
Router#show running
Current configuration : 1323 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $1$Cqw1$hEVpc7p4.l99WgLrw3Mdc.
no aaa new-model
dot11 syslog
no ip routing
no ip cef
no ipv6 cef
voice-card 0
no dspfarm
archive
log config
  hidekeys
no ip address
no ip route-cache
shutdown
duplex auto
speed auto
no ip route-cache
duplex auto
speed auto
no mop enabled
no ip route-cache
no keepalive
ip default-gateway 172.31.35.1
no ip http server
control-plane
line con 0
line aux 0
line 66
no exec
transport input all
line vty 0 4
password *********
login
end
It was mentioned that Fa0/1 should be in a different subnet than WLC, is this true? Then I would need to enable routing?
PC:
Pinging 172.31.35.60 with 32 bytes of data:
Reply from 172.31.35.60: bytes=32 time=1ms TTL=255
Reply from 172.31.35.60: bytes=32 time<1ms TTL=255
Ping statistics for 172.31.35.60:
Reply from 172.31.35.61: bytes=32 time<1ms TTL=255
Reply from 172.31.35.124: Destination host unreachable.
  1  PC [172.31.35.124]  reports: Destination host unreachable.
Trace complete.
Why are packets not flowing between the PC and the WLC Management IP?
Sven,
In order for traffic to be forwarded to the ISE interface the router must either bridge or route the traffic to/from the fast Ethernet interface. To be routed the Interfaces must be on different IP subnets and routing must be enabled on the router. The Hosts (APs, PCs, etc) will need a route to the ISE / WLC IP subnet.
Bill Jenkins
Thank you yet again Bill!
As routing is not really desired (more complex network), what is currentry wrong with the present setup? Shouldn't 2811 just bridge out of the box since the IPs are flat in the same subnet? If my setup doesn't allow bridging then what do I need to change?
The 2811 is a router and does not bridge between interfaces by default.
There are some advantages to using routing vs bridging and all of the examples I can find show routing configured.
However you might be able to configure IRB (Integrated Routing and Bridging) on the router.
The fast Ethernet and the ISE interfaces would need to be in the same bridge group.
This would be similar to how an autonomous AP is configured.
However this may not be supported by Cisco.
Also I do not know for sure if it will work or exactly how it would need to be configured.
I would recommend using the routing solution.
Bill Jenkins
It makes sense that it doesn't bridge interfaces by default. Looks like im missing the IOS 101 course
Today I tried setting bridge-group 1 to both ISE and LAN interfaces but it failed as the Fa0/1 started flapping with bridge 1 protocol ieee & bridge 1 priority 1. Couldn't find a single reason why it shouldn't have worked.
Next I gave every interface their own subnet and enabled routing.
Current configuration : 1536 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 172.32.2.1 172.32.2.99
ip dhcp pool lap
   network 172.32.2.0 255.255.255.0
   default-router 172.32.2.1
   option 43 ascii "172.32.1.2"
no ipv6 cef
voice-card 0
no dspfarm
archive
log config
  hidekeys
ip address 172.32.2.1 255.255.255.0
duplex auto
speed auto
duplex full
speed auto
no mop enabled
ip address 172.32.1.1 255.255.255.0
no keepalive
ip route 0.0.0.0 0.0.0.0 172.31.35.1
no ip http server
control-plane
line con 0
line aux 0
line 66
no exec
transport input all
line vty 0 4
password *******
login
end
I also set up a route from the WAN gateway to the 2811.
show ip route:
Gateway of last resort is 172.31.35.1 to network 0.0.0.0
C    172.31.0.0/16 is directly connected, FastEthernet0/1
     172.32.0.0/24 is subnetted, 2 subnets
C       172.32.1.0 is directly connected, Integrated-Service-E
C       172.32.2.0 is directly connected, FastEthernet0/0
S*   0.0.0.0/0 [1/0] via 172.31.35.1
what happend was this:
PC can ping router and its interface IPs
2811 can ping everything.
WLC can only ping ISE IP and itself.
So the only thing that changed was that the WLC can't ping other IPs on the 2811 anymore.
Could you post the following command output from the WLC?
show sysinfo
show network summary
show interface detailed management
show port summary
3406
