Community Member
WLC Lobby Admin with ACS 5.1
Just wondering if someone knew how to configure a LobbyAdmin account for WLC 7.0 on a 5.1 ACS?  I'm very new to ACS 5.1 and need to advise as to how to configure it.
I've got the ACS policy working that allows me to login to the WLC using a user account with full rights but the Lobby admin account can login with full rights as well.  I've tried setting the custome attributes in the shell profiles with role0-mandatory-LobbyAmbassador, task0-Mandatory-Configure Guest User and task1-Mandatory-Lobby Ambassador User Preferences but it still doesn't work.
2 ACCEPTED SOLUTIONS
Hall of Fame Super Silver
Double check you shell profile... might want to delete it and recreate it, if you are sure it is hitting that policy.
-Scott
can you rebuild the attribute, or try to put the cursor in front of LOBBY and backspace?
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Re: WLC Lobby Admin with ACS 5.1
If you have the WLC there already for management, the role for lobby is role1=LOBBY.  Of course you will have two separate policies in ACS, one for your management and one for lobby.
-Scott
Community Member
I made the changes and added the rule and now I can't login to the WLC with any account.  My hit count goes up but I can't login.
You not defineing a group or AD1.  So your policy is very generic... If you look at mine, I define what group the user is in first then it looks for the others.
-Scott
Community Member
I've created the group and added the lobby admin user to that group. I added the group to the rule and I get a hit count on the role but I still can't login.
You need to define two different shell profiles, don't combine the two together.  For the wlc it is role1=ALL and for lobby its role1=LOBBY.
-Scott
Community Member
I have two shell profiles configured,
On your policy, it shows only WLC-Lobby as your shell profile.  One policy should have WLC-Admin and the other WLC-Lobby.
-Scott
Community Member
I noticed that and corrected it, now I can login with full admin but not with Lobby admin.  I'm checking the debug logs now.
-Scott
Can you screen shot your command sets?
-Scott
Community Member
Screen shot of command set,
Okay... I though you had something there that also might be causing an issue.
-Scott
Community Member
I see in your configuration that you don't have the command set field, is that becuase you are using AD as the source for your users?
Correct... I can use internal user groups if I wanted to, but I'm just testing AD for now.
-Scott
Community Member
The debug for the Lobby account shows a space in the role,
*tplusTransportThread: Jan 24 14:40:10.751: arg[0] = [33][role1=                      LOBBY]
If I use a working account there is no space,
*tplusTransportThread: Jan 24 14:39:08.151: arg[0] = [9][role1=ALL]
I've checked the shell profile and don't see any spaces.
Thats the issue... just recreate it and make sure you don't have sapces in front of LOBBY... this was an issue with 5.1 and 5.2, but 5.3 fixed that.
-Scott
Steve
Community Member
That fixed it, I just removed the spaces.  I'm going to upgrade to v5.3, I've been having this issue for other policy.
Thanks for the help.
1750
