02-26-2008 06:44 AM - edited 07-03-2021 03:27 PM
Does anyone know how to enable management of the WLC from a network which is WLAN enabled?
By default this is not possible but I was told that there is a way to enable this on the controller.
Solved! Go to Solution.
02-26-2008 06:56 AM
Management -> Mgmt via Wireless -> check Enable Controller Management to be accessible from Wireless Clients.
hope this helps.
yong
02-26-2008 06:56 AM
hope this helps.
yong
02-26-2008 07:28 AM
That was it. Thank you very much.
