WLC radius discussion
   Hi all,
I have a mixed setup of WLC and autonomous AP in my network architecture. In our setup all wireless clients passes through mac authentication and then user id/password  authentication. I want for mac authentication request should go to ACS server 1   while for user credential verification the request should go to server2 . In auto nomous AP i can achieve the requirement with folowing configuration.
aaa group server radius rad_eap
server 172.X.Y.103 auth-port 1812 acct-port 1813
aaa group server radius rad_mac
server 172.X.Y.104 auth-port 1812 acct-port 1813
aaa authentication login mac_methods group rad_mac
aaa authentication login eap_methods group rad_eap
radius-server host 172.X.Y.103 auth-port 1812 acct-port 1813 key 7 120A0D16190E2C0C2B25201F6231361B2921
radius-server host 172.X.Y.104 auth-port 1812 acct-port 1813 key 7 0448030704246C4608170120430F180C041C
By the above configuration in AP I can send the mac auth request to 172.X.Y.104 server and EAP authentication to 172.X.Y.103 server.
How ever I want to do the same on my WLC also.
Can anyone guide me how to do the same in GUI or through command line?
Everyone's tags (1)
1 REPLY
Re: WLC radius discussion
If you want to do MAC filtering on one WLAN and standard 802.1x on another you can select which RADIUS server to use is the Security tab -> AAA Servers of each WLAN. To do both on the same WLAN there is no functionality on the WLC to allow you to split the roles the way you want to. Sorry.
-Eric
Cisco Wireless TAC
367
