WLC release 7.4.110.0 and CPI 1.2.1
Hi fellows.
I need a quick answer regarding upgrading 5508 wireless controllers currently running 7.3.112 to 7.4.110
The answer is needed to asess if I MUST or mustn't do the CPI upgrade beforehand.
SInce this is for testing the functionality for apple devices and it is rather urgent I'm wondering what will or wont work if we dont upgrade CPI.
- I'm aware that 7.4.110.0 release notes states that CPI 1.3 is required - I need to klnow what function won't work
Appreciate you feedback.
Sincere Regards
/Mats
Everyone's tags (4)
2 ACCEPTED SOLUTIONS
VIP Purple
As long as your WLC already added to prime, it should work even after upgrade your controller to 7.4.110.0. There may be certain features you many not get unless you go for PI 1.3
If it is for testing, I do not worry about upgrading PI
Rasika
**** Please rate all useful responses ****
Here's a compatiblity Matrix...
http://www.cisco.com/en/US/partner/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html#wp100373
ou didn't mention but I'm guessing you have 1.2 Prime Infrastructure now. You are correct 7.4 WLCs support doesn't show as supported for 1.2.
As Rasika above mentioned, go for the controller upgrade 1st then upgrade Prime second.
My guess is you probably won't lose anything but if you run into problems, it won't be supported.
VIP Purple
Rasika
433
