Community Member
WLC Standard Signatures
According to Cisco, the WLC has 17 built-in standard attack signatures.
In order for IPS signatures updates etc, a separate cisco IPS is to be used. Due to budget constrains, my client is eliminating buying a cisco IPS.
There is a request for me to show that the existing standard 17 signatures do work on the WLC.
A few signatures includes:
1. Broadcast Deauthentication Frame
2. Association/Authentication Request Flood
3. Deauthentication Flood.
May i know how i can simulate these attacks so that it get picked up by the WLC
Community Member
Re: WLC Standard Signatures
I used the Airpcap EX adapter from CaceTech to do exactly what you described.
http://www.cacetech.com/products/airpcap-ex.htm
The aircrack -ng code works with the Airpcap adapter. Generating some basic denial of service attacks is fairly easy. That is how I validated the alarms on the WLC.
Silver
The BackTrack live CD is an excellent recource for penetration testing tools.
http://www.remote-exploit.org/backtrack.html
Community Member
hi
THanks for your information
Did u also only have the standard 17 signatures on your WLC? I assume by enabling "Enable check for all Standard and Custom Signatures" does it all, any attacks will be shown on the trap logs
494
