02-05-2007 02:45 PM - edited 07-03-2021 01:34 PM
Hi Members, can you help me find a way for Configuring only One Controller completely and then synchronising the Other(s) with "One Click", not using the granular Configuration Templates? Regards, Michael
02-07-2007 09:43 AM
OK, if nobody has an Idea... I have found a way with configuring Template Groups on the WCS, where you can bundle Templates and push them to the Controller(s). Regards, Michael
02-07-2007 10:28 AM
An easier way would be to upload the binary configuration file from controller 1 to WCS and then push it from WCS to controller 2. At that point, all you need to change (via console) is the IP address.
02-07-2007 10:37 AM
Thanx, but this was not a usable way in my actual case. Regards, Michael
03-01-2007 06:20 PM
dkhalyav,
Have you been able to do this - use another controllers binary config file on different hardware? From the WCS System/Commands menu?
