Community Member
WLC4402 and ACS receives double authentication request with MS client
I have a 4402 wlc, ACS 3.3 and we use Microsoft client with WPA-TKIP/MSChapv2.
We hardly connect to the WLAN, but after 10 minutes we are disconnected.
We are migrating from LEAP to PEAP, so we create two profiles in the WLC.
LEAP connects good, but PEAP fails.
In the ACS log I can see a double authentication request.
Any idea?
Re: WLC4402 and ACS receives double authentication request with
Try increasing timeout on WLC for radius.
Try checking/ unchecking Fast Reconnect on clients and ACS server.
Rohit Chopra
Community Member
I try to use two SSID's with different EAP-Authentication on the ACS. How did you configure the two Profiles exactly?
Thanks in advance
Community Member
Create two profiles with differente name and same SSID, then you can assign one of them with 802.1x and dynamic wEP, and the second with 802.1x with WPA. The firmware versión should be 4.1.217 or higher
Community Member
but that doesen't solve the problem on the ACS right?! On the ACS I have to configure the device with the ip address and the EAP type (ex. "Cisco Aironet" for LEAP or "Cisco IOS/PIX" for PEAP), and how do that?
Thanks for your feedback
168
