wlccp on L3
I am using a WLSM as a WDS. All my APs are connected via several switches and are using L3 to connect back to the WLSM. Since wlccp is a multicast and it cant be routed, what will be the implication on my setup.
1 REPLY
Re: wlccp on L3
You can configure your APs with the WDS / WLSM host IP address.
The AP and WLSM then communicate using unicast.
Bas Kokken
Guana Network Architects
110
