per
Wlse 2.13.1u doesn't save templates
After upgrade of wlse to 2.13.1u the templates can't be saved.
The log entries are :
[Thu Sep 7 09:56:24 2006] [error] /opt/CSCOets/modperl-scripts/blank.html not found or unable to stat
[Thu Sep 7 09:58:16 2006] [error] [client 172.21.64.35] File does not exist: /opt/CSCOets/NAS/webapps/ROOT/wlse/configure/blank.html
[Thu Sep 7 09:58:31 2006] [error] [client 172.21.64.35] File does not exist: /opt/CSCOets/NAS/webapps/ROOT/wlse/configure/blank.html
Best regards
Per
1 REPLY
Bronze
Re: Wlse 2.13.1u doesn't save templates
1. All log files have pre-defined size limits of 10000 lines, or 20000000 bytes, which ever occur first.
2. Only the HA log file size is configurable via WLSE UI.
3. Once the log file size limit is met, the current log file will be moved to a backup log file and a new log file will be created.
4. Also, each time you stop and restart services via the CLI commands 'services stop' & 'services start' , all current log files will be moved to backup log files, and new log files will be created.
135
