WLSE 2.13, MFP Policy, ios 12.3(8)JA and 1131 reset w xp with intel 2200
I actived Management Frame Protection in WLSE with 1131 and ios 12.3(8)JA.
when any wds find error with Management Frame Protection, do anynithing that reset all (with blue screen) intel centrino with intel wireless card 2200 at the same time.
The next time that you start the notebooks, when you active the wireless, a new reset and a blue screen.
I downgrade ios version to 12.3(7)
and disable Management Frame Protection, then the problem is resolved.
any idea?
Re: WLSE 2.13, MFP Policy, ios 12.3(8)JA and 1131 reset w xp wit
With intel 2100 and 12.3(8)JA happen too
Hello
just a short question...how and where (AP or/and WLSE?) do you disable MFD?
many thanks for answering
Oliver
i disable MFP in WLSE -->IDS--> Manage Network-Wide IDS Settings -->Management Frame Protection
it is disable by default
i enabled it, them the centrinos with old drivers fail. When microsoft online crash analysis analyzed it, returns a intel driver error in w70n51.sys and show a link to a new intel driver in the intel web site.
i downgrade ios to 12.3.7JA because disable MFP in wlse was not enough.
152
