wlse 2.13u
hi,
i've just upgrade the wlse and now i can't create new templates. Do you have an idea?
That are the error log messages:
Fri Jul 7 07:54:40 2006] [error] /opt/CSCOets/modperl-scripts/blank.html not found or unable to stat
[Fri Jul 7 07:56:04 2006] [error] [client 192.168.1.25] File does not exist: /opt/CSCOets/NAS/webapps/ROOT/wlse/configure/blank.html
Emiliya
Blue
Re: wlse 2.13u
Any errors during the upgrade?. Did you try to re-boot the WLSE and see if it makes any difference?
Re: wlse 2.13u
no, there aren't some errors, during the upgrade, but the same problem i have with another one machine (also 2.13).
113
