WLSE 2.5 and AP350 IOS
Hi all,
I have upgraded some of our AP350 to the IOS Image 12.2(13)JA1 with the Cisco Conversion Tool.
Now I would like to change the configs via WLSE 2.5, which tells me that it doesn't support this image.
Has anybody the same problem or maybe a solution?
Thanx very much for your help!
Re: WLSE 2.5 and AP350 IOS
Watch your upgraded 350s...there has been many instances where the new IOS image has made the 350s unstable
Blue
You can use 12.2(13)JA1 with WLSE 2.5, though it is not officially supported, but you can still use it. Just ignore the warnings etc.
How do you ignore the warings etc and continue the upgrade ? I have clciked [Yes] on the 'Save Confiramtion' windows and I get a Job 'failed'.
How should I apply the 12.2(13)JA1 to Ap350s ?
142
