Community Member
WLSE 2.7 wont create jobs
When I create either an firware or config job, I complete all the steps, selecting devices, firware or config and schedule either now or in the future and when I get to the Save step, the page remains blank with "You are creating job: XXX" at the top. It doesn't even register the job, I can create a job with the same name over an over again without complaint. I've tried with different versions of IE, popups are disabled. It used to work just fine. I can't find any clues in the logs. Any ideas?
1 REPLY
Bronze
Re: WLSE 2.7 wont create jobs
WLSE 1130 users - upgrade to a newer release, e.g. WLSE 2.11.
WLSE 1105 users running release 2.7.1 or 2.7 - Download patch WLSE-2.x-CSCsb39389 from Software Center, and follow the associated installation readme instructions (available at): http://www.cisco.com/cgi-bin/tablebuild.pl/wlan-sol-eng.
124
