WLSE Device full names all the same.
I have all of my WAP's connected and managed by my WLSE but it showing that they all have the same name under Devices > Group Management as well as when I try to deploy new templates. If I dig into device explorer it shows the "Full Name" as the wrong name but the "SysName" name is the correct name. If I log into each device the host names are correct.
Any idea's how to get the WLSE to assign the right name?
1 REPLY
Re: WLSE Device full names all the same.
Having the same name for all devices can happen if the name format is defined incorrectly under Device->Discover > Advanced Options. The hostname format should be %hostname%. Check if it is configured correctly and if not configure the same properly so that the issue is resolved.
124
