WLSE -> WCS upgrade license question
We need to upgrade our WLSE to WCS but our sales people bought the wrong license (WCS-Standard-K9) Is it possible to upgrade the WLSE to WCS with this license and just get the conversion CDs needed from you ?
2 ACCEPTED SOLUTIONS
Re: WLSE -> WCS upgrade license question
You would need to contact licensing at Cisco for the exact answer to that. The contact information is on the WCS support page or you can call TAC.
Hall of Fame Super Red
Hi Gudmundur,
This will not work, plus you have probably paid more that is necessary as the Upgrade Licenses are le$$ to encourage this migration. You should,as noted by Dennis contact your SE or;
licensing@cisco.com
Converting Existing CiscoWorks WLSE to Cisco WCS Licenses
CiscoWorks WLSE (Models 1130-19 or 1133) can be converted into a server that runs Cisco WCS. This allows customers of CiscoWorks WLSE to migrate to the Cisco Unified Wireless Network architecture using their existing CiscoWorks WLSE platform. CiscoWorks WLSE conversion SKUs are price-adjusted to make transitioning from CiscoWorks WLSE to Cisco WCS cost-effective.
Once converted, a CiscoWorks WLSE is no longer a self-contained appliance; it becomes a server that runs Cisco WCS software using RedHat Linux ES v. 4.0. The converted CiscoWorks WLSE operates as a brand new Cisco WCS installation and supports only lightweight access points and wireless LAN controllers that are running Lightweight Access Point Protocol (LWAPP). Stand-Alone (autonomous) access points are not supported by a converted CiscoWorks WLSE.
All WCS-WLSE-UPG-K9 SKUs ship with two special conversion CDs. These CDs will check to make sure that a CiscoWorks WLSE is installed prior to beginning the Cisco WCS conversion process. The conversion software will not install if the CiscoWorks WLSE software check, performed by the conversion software, does not pass.
Note: Please take note of the following special considerations for CiscoWorks WLSE conversions.
CiscoWorks WLSE Express (Model 1030) and CiscoWorks WLSE (Models 1105) are not supported with this SKU. Do not install the CiscoWorks WLSE CDs on to the CiscoWorks WLSE Express (Model 1030) appliance or CiscoWorks WLSE (Model 1105). This conversion is not supported and will not work.
A CiscoWorks WLSE that has been converted to Cisco WCS cannot be reverted back to operate as a CiscoWorks WLSE.
To find the model number of a CiscoWorks WLSE, look at the compliance label on the bottom of the chassis front bezel. Only CiscoWorks WLSE with a compliance label that says 1130-19 or 1133 can be converted to Cisco WCS.
Please see Appendix C for information about receiving support for existing SMARTnet® (hardware support) contracts for CiscoWorks WLSE.
Customers that are migrating their existing CiscoWorks WLSE to operate as a Cisco WCS server should select from the WCS-WLSE-UPG-K9 SKU family and then select one of the sub-SKU options based on the following:
Base or Location
Access point quantity. (The CiscoWorks WLSE conversion CD's do not automatically provide support for a set number of access points or location services. The number of lightweight access points supported as well as Cisco WCS location is selected by the customer based on the WCS-WLSE-UPG-K9 family sub-SKU. Customers can select the sub-SKU that contains the access point count and Cisco WCS option that they wish to support.)
A Cisco Ordering Tool sample for WCS-WLSE-UPG-K9 is displayed in Link.
PAK Certificate, Instructions and CD
Customers that purchase the SKU family WCS-WLSE-UPG-K9 will automatically receive, by U.S. mail, two special CDs containing the CiscoWorks WLSE to Cisco WCS conversion software, as well as the PAK certificate, instructions on how to register the PAK and links to Cisco WCS manuals and release notes. CiscoWorks WLSE conversion software cannot be downloaded.
http://www.cisco.com/en/US/products/ps6305/products_data_sheet0900aecd804b4646.html
Hope this helps!
Hi Gudmundur,
licensing@cisco.com
Base or Location
Hope this helps!
Hi Gudmundur,
licensing@cisco.com
Base or Location
Hope this helps!
Hi Gudmundur,
licensing@cisco.com
Base or Location
Hope this helps!
Thank you for your replies, I've decided to install WCS on another blade server that way I can migrate our customers over one by one.
regards,
Gudmundur
Hi guys,
Sorry for the double info in the post! The edit function does not seem to work for me anymore :(
Rob
607
