03-09-2004 08:19 PM - edited 07-04-2021 09:26 AM
When you upgrade the AP1200 from VxWorks to IOS, the upgrade process changes the SNMP Read-only string to "public" from whatever it was earlier. Anyone experianced that before. Please help!
03-10-2004 06:41 AM
Have not seen that. In Vxworks, All users with at least "snmp + admin" rights can be used as community strings. Before converted to IOS, does the AP have a user "public" exist?
03-10-2004 11:34 AM
I've had the same problem with the SNMP string changing.
The whole conversion process seems to be rocky (in my experience). I have different results between WLSE and the CAC tool. No matter what tool I use I still have to manually set some of the security settings...
03-10-2004 01:22 PM
Did you get a fix for this or you had to set it manually everytime? My customer has over 100 APs and if he has to change every AP settings manually that is a true inconvenience.
03-12-2004 08:52 PM
I haven't been able to get a fix and the TAC hasn't been any help.
