WLSE version 21.5u upgrade and problem thereafter
astanislaus
Level 2
Level 2
Cisco WLSE Wireless Lan Solution Engine was recently upgraded to release 2.15u. Following the upgrade, the device seems to shut itself down after approximately 30 - 40 minutes of uptime.
This has occurred three times in 24 hours
I have all the install logs, fault logs, etc. but I cannot post them here.
I need some tips on what I need to look at in these logs for troubleshooting this problem.
smalkeric
Level 6
Level 6
When this issue occurs, ensure these events are properly handled:
The hostname of the certificate must exactly match the hostname used to access the device.
Pop-up blockers must be disabled.
The WLSE requires Microsoft Internet Explorer 6.0 SP1 and Java Plug-in 1.4.2 or later.
An upgrade must not be done without its correspondent patch.
http://www.cisco.com/en/US/docs/wireless/wlse/2.11/upgrade/guide/211upgr.html
