WLSE, WPA v1 and v2
Using
- WLSE 1130 Release 2.15.2
- AP1250 IOS 12.4(10b)XXX
Hi all,
When creating template with WLSE, we have to choose between WPA version 1 or 2, which generate IOS :
- authentication key-management wpa version 1
or
- authentication key-management wpa version 2
With Access point older than 1250, there is no consequence, Only the "Encryption settings" will be significant, and so we can use WPAv1 AND v2 simultaneously (AES CCMP+TKIP).
With an 1250 access point, In the SECURITY / SSID, for a SSID we have to choose between
- WPA
- WPA version 1
- WPA version 2
Th first one will permit to use v1 AND v2 simultaneously, whereas the second choice limit to version 1 and the third choice limit to version 2.
The problem is : In WLSE, we only have TWO CHOICES : v1 or v2 exclusively ! and not the only "WPA" choice ...
How can we specify in the template to configure the AP to use version 1 AND version 2 ?
Thanks.
SD.
1552
