Community Member
WPA auth down when first ACS is DOWN
The system consists of 10 standalone AP.
The client is authenticated through WPA MsCHAPv2 with TKIP.
The remote servers are two ACS version 3.2.
When the server ACS 10.0.0.1 went down some client disconnect.
It is possible that the AP does not realize in time that the first server is down then the authentication request goes timeout?
Is possible change the time in an AP it is checked if a server is down?
ip subnet-zero
no ip domain lookup
aaa new-model
aaa group server radius rad_eap
server 10.0.0.1 auth-port 1645 acct-port 1646
server 10.0.0.2 auth-port 1645 acct-port 1646
aaa authentication login CONSOLE none
aaa authentication login VTY line
aaa authentication login eap_methods group rad_eap
aaa cache profile admin_cache
all
aaa session-id common
dot11 ssid test
authentication open eap eap_methods
authentication key-management wpa
guest-mode
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
ssid test
speed basic-1.0 basic-2.0 basic-5.5 basic-11.0
channel 2412
station-role root
rts threshold 2312
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
hold-queue 160 in
interface BVI1
ip address 10.0.0.3 255.255.255.0
no ip route-cache
ip default-gateway 10.0.0.254
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
snmp-server view basic iso included
snmp-server community wlse RW
snmp-server community public RO
snmp-server enable traps tty
radius-server attribute 32 include-in-access-req format %h
radius-server host 10.0.0.1 auth-port 1645 acct-port 1646 key qazse4
radius-server host 10.0.0.2 auth-port 1645 acct-port 1646 key qazse4
radius-server vsa send accounting
thanks.
Mirko Severi
1 REPLY
Silver
Re: WPA auth down when first ACS is DOWN
The shared secret key that you configure on the WLC and the ACS server must match. The shared secret is case sensitive.
Verify you configuration also..
debug dot1x events enable-Enables the debug of all dot1x events
For further information click this link.
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a008095382f.shtml#c3
113
