WPA cisco877w and Aironet1121G
I was trying to set up Cisco877w and Aironet1121 G as a repeater. All works fine without any security on. However when I put WPA with shared key, Access point cannot associate to router anymore. I used config example from cisco.com and it doesn't work. Can anyone help?
interface Dot11Radio0
description Wireless Customer LAN connection
ip nat inside
ip virtual-reassembly
encryption mode ciphers tkip
ssid XXXX
authentication open
guest-mode
authentication key-management wpa
wpa-psk ascii pre-shared_key
speed basic-1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2452
antenna receive right
antenna transmit right
antenna gain 128
station-role root
end
dot11 ssid XXX
authentication open
infrastructure-ssid
bridge irb
no ip address
no ip route-cache
ssid XXX
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
station-role repeater
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
It is giving me a message like that : DOT11-4-CANT_ASSOC
I'm sure there is no misstype. and i cannot see any error messages on router, even while debugging.
Cheers
Chris
1 REPLY
Re: WPA cisco877w and Aironet1121G
The issue may be due to lower gain antennas installed. the best way to use directional antennas in point to multipoint places and directional antenna in point to point places.
108
