WPA problem
Hi everyone,
We're having a WPA problem with a new 1130 AP. Below are debug snippets and below that is our sanitized config. Any ideas?
Thanks!!
Stephen
*Mar 1 01:43:51.813: Client 0012.1714.1dad failed: Dot1x replay count not from most recent request,exp=2, act=1
*Mar 1 01:43:51.884: Client 0012.1714.1dad failed: Dot1x MIC mismatch
*Mar 1 01:43:51.983: dot11_auth_client_abort: Received abort request for client 0012.1714.1dad
*Mar 1 01:43:51.983: dot11_auth_client_abort: No client entry to abort: 0012.1714.1dad for application 0x1
version 12.4
no service pad
service password-encryption
no aaa new-model
clock timezone CST -6
clock summer-time CDT recurring
dot11 ssid wireless
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 7
power inline negotiation prestandard source
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm tkip
ssid wireless
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
dfs band 3 block
channel dfs
station-role root
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 1.1.1.2 255.255.255.0
no ip route-cache
ip default-gateway 1.1.1.1
no ip http server
ip http authentication local
ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
end
1 ACCEPTED SOLUTION
Re: WPA problem
Hi microsage,
It might sound stupid question but I have seen a problem like this cisco has or had a problem with long WPS-PSK keys.
You have to restrict youself between 8 - 12 Char. if it is the same problem I have seen.
That is a big problem if you see the error message
R-Home(config-ssid)#wpa-psk ascii 0 test
Invalid key length, expecting 8 to 63 characters
best regards
Christian
Re: WPA problem
Hi microsage,
best regards
Christian
Re: WPA problem
We shortened our key from 19 chars to 11 and it works fine now. Thanks!!
We have tkip and aes setup. It only works with tkip though. Any suggestions there?
Re: WPA problem
Hi Microsage,
works ok, and is supported by many chips/firmware and drivers.
BTW what 12.4 version the problem stil is in it.
glad you got it to work please remember til give a grade ;o)
Best regards
Christian
Re: WPA problem
Cisco IOS Software, C1130 Software (C1130-K9W7-M), Version 12.4(10b)JA, RELEASE SOFTWARE (fc2)
2071
