09-22-2006 01:06 PM - edited 07-04-2021 01:08 PM
I am currently using WPA2-spk. I want to add another layer of security. I know I could do EAP. I am also looking at mac authentication. But I want to host the mac list on an ACS server. Setting the the mac addresses on the ACS server is pretty cut and dry, but how can I configure the ap to look to the ACS server for its mac list? And, how can I get WPA-spk and mac authentication to work together?
09-24-2006 10:02 PM
Hi Jared,
you can do this by setup the following:
Webinterface:
1. Securtiy -> Server Manager
Setup the ACS IP in the list "MAC Authentication" in the section "Default Server Priorities".
2. Securtiy -> Advanced Securtiy
In the section "MAC Address Authentication" use the radio button "Authentication Server Only" or "Local List if no response from Authentication Server" for a fallback configuration!
IOS Interface from config mode:
aaa group server radius rad_mac
server 10.20.40.37 auth-port 1645 acct-port 1646
and
aaa authentication login mac_methods group rad_mac
or
aaa authentication login mac_methods group rad_mac local (for local fallback)
I have not tested this, cause the MAC of the supplicants is to easy to sniff and any medium skilled person may used a sniffed MAC to enter the first authentication stage!
Better use a setup with EAP-FAST or PEAP!
I hope that helps.
Best regards,
Frank
I hope that helps.
09-25-2006 05:44 AM
I got that far, but I am still not seeing the mac authention portion work. I am looking at my ACS logs and I don't even seen an attemtp to authenticate the mac address to the ACS. I currently have open authentication set up. When I add the option with mac address, then the wireless breaks and I cannot use the Access Point any longer.
09-25-2006 05:51 AM
Frank,
I just found an error message that states that mac authenication is not supported with wpa-spk. So it looks like I am stuck with EAP as I figured I would.
I was just trying it out to see if it was a possibility. Thanks for responding.
09-26-2006 03:37 AM
Hi Jared,
you are totally right!
Have a look here:
Sometimes RTFM helps.
I have learned something, too.
Best regards,
Frank
