Silver
WPA2 Authentication
I currently have a 5508 controller which uses a radius server and AD groups for security. Is it possible to also enable WPA2 authentication? I would like to enable corporate iPads to connect to the corporate wireless network. Any advice would be appreciated.
Posted by WebUser Terence Pearson from Cisco Support Community App
WPA2 Authentication
I am using wlc 2504 with 802.1x with WPA2 authentication and that's seems working on IPhone didn't tried Ipads. If you want to give only internet access to IPads i would create another network and use that.
Silver
WPA2 Authentication
I have a guest network setup for internet only access. I want to give the iPads access to our internal corporate network. They will be used to access the intranet and our internal SharePoint site.
Hall of Fame Super Silver
WPA2 Authentication
I have a few iPads I test with that is using WPA2/AES PEAP with AD credentials.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
WPA2 Authentication
I can't see a problem why it don't work. I think Scott alos confirms it works.
Re: WPA2 Authentication
Oh it works:). On every install, I make sure that my clients test their iPads and iPhones as many or the users have them. Never had an issue and instill test with an iPad v1 to make sure.
-Scott
126
