WPA2 with Active Directory for 802.1x?
Hey all,
I'm working on a wireless project with 8 1130 APs. I need to do WPA2 if possible and integrate users from active directory.
I'm search cisco.com, and not finding alot of help.
Any help would be great
Chris Serafin
Security Engineer
chris@chrisserafin.com
Re: WPA2 with Active Directory for 802.1x?
This is possible and I would say there is a lot of documentation on cisco.com on this subject. Just look under Tech Support & Documentation and find your wireless product. It will include configuration examples which are very helpfull.
You will need to run a radius server between your ap's and active directory. We use Cisco ACS 4.1, but you could use freeradius or microsoft radius.
regards,
Rutger
I will keep looking, but I have yet to find any good documentation.
Any links, or docs you use?
Thanks for anything.
Chris Serafin
cserafin@rkon.com
I found this document under 1130 AP:
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008054339e.shtml
The document is written for a 1300 AP, but setting upp wpa2/radius/ad is nearly the same on all of Cisco's AP's I would say.
Rutger
278
