WPAIE not found and required
Can any body tell me what this dbeug output on 1100 means?
Sep 28 15:00:06.240: Client 0011.21ce.da30 failed: WPAIE not found and required
Bronze
Re: WPAIE not found and required
I believe this message means the client does not send out WPAIE in the association request.
This would seem to refer to a beacon information element specifying WPA parameters, as mentioned in these two documents:
http://support.microsoft.com/?kbid=815485
http://www.cisco.com/en/US/products/hw/wireless/ps4555/prod_bulletin09186a00
801f7ce2.html.
Hope this helps.
Re: Sep 28 15:00:06.240: Client 0011.21ce.da30 failed: WPAIE not found and required
When using Cisco AP and Cisco WGB/Universal Client, the above message indicates while both device's radios, eg 5GHz radio, have the correct SSID, there is a mismatch in encryptions on the radios. One device may have TKIP while the other device has AES encryption for the same SSID/radio.
To rectify the situation, eg, removing TKIP and adding AES on one radio, I suggest following sequential config steps:
-first disable SSID on the affected radio (eg, 5GHz radio per our example) interface of the device by 'no ssid '
-remove encryption by 'no encryption mode ciphers aes-ccm tkip'
-then, add encryption by 'encryption mode ciphers aes-ccm aes'
-add ssid on the radio by 'ssid '
-end
-wr mem
Ensure no shut on both devices' radios.
Done!
4905
