WRVS4400N V2 doesn't allocate DHCP addess on wireless WEP
My WRVS4400N,
V2.0.2.1
CPU:STAR 9202
Doesn't allocate IP address on DHCP for anything but the Open SSID.  All others, WEP, WPA, WPA2, nothing.
I tried different clients, Intel Centrino wifi, Cisco, AG-CB21 same results.
The config is std, I tried one VLAN for ALL SSID, I tried different VLANS, same.
On the Wired side, no problem.
Thank you,
Nicos
Basic Settings
Wireless Network Mode:
Wireless Channel:
Multiple BSSID:
Enabled    Disabled
SSIDSSID NameSSID Broadcast
SSID1
SSID2
SSID3
SSID4
© 2009 Cisco Systems, Inc. All rights reserved.
LAN
IPv4
VLAN :
Local IP Address: . . .
Subnet Mask:
IP Reserved for Internal Usage:
192.168.1.(Range:1..254)
Server Settings (DHCP)
DHCP Server:Enable  Disable  DHCP Relay
Starting IP Address:
192.168.3.
Maximum Number of DHCP Users:
Client Lease Time:
  minutes (0 means one day)
Static DNS 1: . . .
Static DNS 2: . . .
Static DNS 3: . . .
WINS: . . .
Static IP Mapping
Static IP Address: . . .
MAC Address: : : : : :
Host Name:
IPv6
IPv6 Prefix:IPv6 Postfix:Prefix Length:
Router Advertisement:
Enable  Disable
DHCPv6
DHCPv6: Enable  Disable
Lease time
DHCP6 address range start:
DHCP6 address range end:
Primary DNS:
Secondary DNS:
570
