12-31-2003 01:20 PM - edited 02-20-2020 11:10 PM
Hi All..
Am trying to setup a remote site using a Pix506e on the remote end and a 3005 Concentrator at the headend. I am getting an error on the pix that says "VPN Peer: ISAKMP: No remote peer info for 12.109.169.12/500 - peer:0" That IP address is the 3005 and is listed in the crypto map set peer statement on the pix. debug shows that an IKS tunnel is created but not the IPSEC tunnel. I have a rapidly approcahing deadline so any thoughts are helpful.
TIA
Ron...
01-01-2004 03:20 PM
I guess first off make sure you've followed the sample config to the letter:
01-04-2004 06:20 PM
That was the example we had tried. Copied it exactly... still got the errors. Becuse of the deadline we were facing we moved to a different solution but thanks for your help. We'll be trying this configuration again at a later date.. Hopefully we'll have more luck then.
