3030 Lan To Lan: Can't chose MD5 in IKE drop down
What am I missing?
I'm following the PIX 501 to 3030 Lan-To-Lan doc, working on the 3030 side.
When I go to fill in the IKE Proposal, I don't see any proposal with MD5 in it to chose from. I see multiple SHA ones. The MD5s are activated. I can see other ezvpn PIX and software clients using MD5.
What am I missing?
It's like MD5 is not valid, or I've turned off the ability to select it somewhere.
1 REPLY
Silver
Re: 3030 Lan To Lan: Can't chose MD5 in IKE drop down
You seem to be running into a unique problem. I could not find any bugs related to this isuue and neither have I hear of such a problem. I guess a save followed by a reload could be your best bet, unless if you are looking in the wrong place.
147
