Community Member
3640 - vpn - sonicwall pro 230
i received these requirements from a company that needs a VPN tunnel to our site.
they use Sonicwall pro 230, we have cisco 3640.
script sample / FAQ links would appreciated.
Here?s is what i got from them:
IPSec Gateway Address =
IPSec Mode = IKE Using Preshared Secret
Exchange = Main Mode
Phase 1 DH Group = Group 2
SA Life Time (Secs) = 28800
Phase 1 Encrypt/Auth = DES & MD5
Phase 2 Encrypt/Auth = Encrypt and Authenticate (ESP DES HMAC MD5)
Shared Secret = xxxsomesecretphrasexxx
Keep Alive = Enabled
Phase 2 DH Group = Group 1
We use a Sonicwall Pro 230, your Cisco 3640 will be slightly different in it's setup. you may need information/clarification on "translating your settings". We may need to play with the Encrypt/Auth settings to find a "compatible" pair.
The only information I'll need to setup the Tunnel completely is :
Your IPSec Gateway Name/Address (e.g.
Destination Network & Subnet Mask (e.g. Network = and Subnet =
