3DES VPNs with VoIP failover on ADSL 8Mb circuits
Anyone have a good value solution for the following requirements:
2 x office sites located ~20Km apart with 7 people in each office.
2 x ADSL circuits are being installed at each office. Performance 8Mbps downstream 768Kbps upstream contended 20:1 at best.
WAN Requirements:
Two tripleDES encrypted site-to-site VPN tunnels. The first VPN will service general office network data, call this VPN 1.
The second VPN must be dedicated for VoIP in order to service a 3rd Party non-cisco VoIP telephone system, call this VPN 2.
The VoIP system will have 15 users but assume maximum of 8 simultaneous VoIP calls.
Both tunnels should be always up once connected (keepalives). Whether this is serviced by a router with 2 ADSL interfaces, or just two DSL modems into
an ethernet router doesn't matter.
Failover from VPN 1 to 2 and vice versa is required, even though this may have an impact on VoIP performance i.e. number of calls allowed is reduced.
No load-balancing of the two links is needed.
Seven secure remote user dialup VPN's are also required, VPN's 3-10, for mobile workers to access the corporate network outside normal office hours.
Existing smoothwall linux firewalls are to be replaced with a suitable Cisco solution with a standard best practice security policy applied.
LAN Requiremets:
To service routers/firewall/desktops/servers/printers and any other network devices. 24port Gigabit copper switch at each office would be nice
but depends on total cost, they will settle for a 24 port Fast Ethernet switch at each office.
I'm considering 1841 router with dual HWIC-1ADSL interfaces and ASA5505 for VPN/Firewall with either a Catalyst 2960 model:WS-C2960-24TT-L or Catalyst 500 model:WS-CE500-24TT for local switching.
All advice welcomed.
Dougie
1 REPLY
Re: 3DES VPNs with VoIP failover on ADSL 8Mb circuits
Sorry posted in wrong forum. Re-posting in general VPN forum.
106
