Community Member
ACS 3.3 and VMWARE compatibility
Hi all,
I want to ask if there are some experiences on ACS 3.3 for Windows running on a virtual machine under VWWARE
Is it a tested configuration?
My question sourced by problems to import certificates on an ACS running under the a Windows virtual machine.
The problem is not present on an ACS running on a physical machine ( running the last patch of 3.3 release)
1 REPLY
Re: ACS 3.3 and VMWARE compatibility
Although not supported, ACS on a VM works just fine. We run it that way and have certs on it.
205
