ASA 5505 FTP Port forward - Help!
So apparently I am doing something wrong and I cannot get FTP access to my server. Here is my config, does anyone have any advice?
thanks
ASA Version 8.2(5)
hostname ciscoasa
enable password bMN53GxNoKlQNrTC encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
 switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
 nameif inside
 security-level 100
interface Vlan2
 nameif outside
 security-level 0
 ip address 23.24.241.50 255.255.255.248
ftp mode passive
object-group service DM_INLINE_SERVICE_1
 service-object gre
 service-object tcp eq pptp
object-group service gre tcp
 description 500
 port-object eq 500
object-group service DM_INLINE_TCP_1 tcp
 port-object eq www
 port-object eq https
object-group service DM_INLINE_TCP_2 tcp
 port-object eq ftp
 port-object eq ftp-data
access-list outside_access extended permit tcp any interface outside eq smtp
access-list outside_access extended permit tcp any interface outside object-group DM_INLINE_TCP_1
access-list outside_access extended permit object-group DM_INLINE_SERVICE_1 any interface outside
access-list outside_access extended permit gre any interface outside
access-list outside_access extended permit tcp any interface outside eq pptp
access-list outside_access extended permit tcp any interface outside object-group DM_INLINE_TCP_2
access-list internalout extended permit ip any 192.168.1.0 255.255.255.0
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) tcp interface smtp 192.168.1.12 smtp netmask 255.255.255.255
static (inside,outside) tcp interface https 192.168.1.12 https netmask 255.255.255.255
static (inside,outside) tcp interface pptp 192.168.1.12 pptp netmask 255.255.255.255
static (inside,outside) tcp interface 500 192.168.1.12 500 netmask 255.255.255.255
static (inside,outside) tcp interface www 192.168.1.12 www netmask 255.255.255.255
static (inside,outside) tcp interface ftp 192.168.1.12 ftp netmask 255.255.255.255
access-group outside_access in interface outside
route outside 0.0.0.0 0.0.0.0 23.24.241.54 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect pptp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:42f09ce2e4f14b07a896b81bcacdbcfd
: end
782
