ASA 5510 internal traffic dropped
TPtheStig
I am trying to create a pretty basic two interface setup (inside and outside, or as I have labled them in my config LAN and WAN). I have a web server on 192.168.7.3 and can access it from an outside network just fine, but cannot access the page internally (like say on machine 192.168.7.4)! What gives? I am sure it is something basic. I appreciate any help. If you can't tell I am new to ASA's and am just trying to figure this stuff out as I go along. The setup is pretty basic, Internet----ASA----Inside network (where the web server is and some other machines). No DMZ or any other routers.
The packet tracer in ASDM says that everything is fine but I can't connect internally to the web server. The logs show
19:34:07|106015|192.168.7.3|192.168.7.4|Deny TCP (no connection) from 192.168.7.3/80 to 192.168.7.4/63746 flags ACK  on interface LAN
19:34:06|106015|192.168.7.3|192.168.7.4|Deny TCP (no connection) from 192.168.7.3/80 to 192.168.7.4/63746 flags ACK  on interface LAN
19:34:06|106015|192.168.7.3|192.168.7.4|Deny TCP (no connection) from 192.168.7.3/80 to 192.168.7.4/63746 flags SYN ACK  on interface LAN
19:34:05|106015|192.168.7.3|192.168.7.4|Deny TCP (no connection) from 192.168.7.3/80 to 192.168.7.4/63746 flags ACK  on interface LAN
19:34:04|106015|192.168.7.3|192.168.7.4|Deny TCP (no connection) from 192.168.7.3/80 to 192.168.7.4/63746 flags ACK  on interface LAN
19:34:04|106015|192.168.7.3|192.168.7.4|Deny TCP (no connection) from 192.168.7.3/80 to 192.168.7.4/63746 flags SYN ACK  on interface LAN
19:34:03|106015|192.168.7.3|192.168.7.4|Deny TCP (no connection) from 192.168.7.3/80 to 192.168.7.4/63746 flags SYN ACK  on interface LAN
Config file below:
: Saved
: Written by enable_15 at 19:11:12.354 UTC Wed Feb 29 2012
ASA Version 8.0(2)
hostname ciscoasa
enable password xBWw8/XdalZA81PL encrypted
names
interface Ethernet0/0
nameif WAN
security-level 0
ip address 75.XX.XX.XX 255.255.255.248
interface Ethernet0/1
nameif LAN
security-level 100
ip address 192.168.7.1 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
management-only
passwd 2KVQrbNIdI.2EYOU encrypted
ftp mode passive
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list PERMIT_IN extended permit tcp any host 75.XX.XX.XX eq www
access-list PERMIT_IN extended permit tcp any interface WAN eq www
access-list PERMIT_OUT extended permit ip 192.168.7.0 255.255.255.0 any
access-list PERMIT_OUT extended permit ip host 192.168.7.3 any
access-list PERMIT_OUT extended permit ip any host 192.168.7.3
pager lines 24
logging enable
logging asdm informational
mtu WAN 1500
mtu LAN 1500
mtu management 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-602.bin
no asdm history enable
arp timeout 14400
global (WAN) 1 interface
global (LAN) 1 interface
nat (LAN) 0 192.168.7.0 192.168.7.50
static (LAN,WAN) tcp interface www 192.168.7.3 www netmask 255.255.255.255
access-group PERMIT_IN in interface WAN
access-group PERMIT_OUT in interface LAN
route WAN 0.0.0.0 0.0.0.0 75.XX.XX.XX 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
no crypto isakmp nat-traversal
telnet timeout 5
ssh 192.168.7.3 255.255.255.255 LAN
ssh timeout 5
console timeout 0
dhcpd dns 8.8.8.8
dhcpd address 192.168.7.50-192.168.7.150 LAN
dhcpd enable LAN
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
service-policy global_policy global
username admin password Zui7fY5vmGCfVcCX encrypted
prompt hostname context
Cryptochecksum:dd7395b12f7cbfb5f00787717abd54a8
: end
mirober2
The problem here is asymmetric routing. See the following doc for more details:
https://supportforums.cisco.com/docs/DOC-14491
To summarize, the ASA needs to see both sides of the TCP connection (client -> server, and server -> client). The logs you posted indicate the SYN from the client is making it to the server without going through the ASA (which is expected if they're both on the same LAN). However, the response from the server is going back to the ASA.
I would check the subnet mask and routing table on the server and make sure the server sends its replies back to the client directly instead of going to the ASA. If that looks good, make sure the server is learning the correct ARP entry for the client.
-Mike
