ASA 8.4(7) Failover configuration
I am doing an active/standby failover configuration and I would like to have the virtual mac addresses configured.
I'm wondering if I need to do them both on the primary unit and the secondary unit, or just the primary unit. The inside, outside and management interfaces have already been configured with a standby IP. Also if virtual mac addresses are the burned in addresses of the physical interfaces would that cause a problem?
The reason we need to have virtual mac addresses is because our service provider has an additional external address range which the company uses and it is pointing to the outside interface of our firewall. In the event that the second firewall boots up first it may cause arp issues for the second external address block.
These are two 5510 firewalls running version 8.47-7
Here is the configuration:
failover lan unit primary
failover lan interface FAILOVERLINK Ethernet0/1
failover interface ip FAILOVERLINK 172.50.48.1 255.255.255.252 standby 172.50.48.2
interface Ethernet0/1
no shutdown
failover link STATELINK Ethernet0/3
failover interface ip STATELINK 172.50.49.1 255.255.255.252 standby 172.50.49.2
interface Ethernet0/3
no shutdown
failover mac address Ethernet0/0 f0f7.55f3.065b 8843.e10c.42ea
failover mac address Ethernet0/2 f0f7.55f3.065c 8843.e10c.42ec
failover mac address Management0/0 f0f7.55f3.065e 8843.e10c.42ee
SECONDARY UNIT
failover lan unit secondary
no shutdown
no shutdown
91
