ASA licenses, one license or two, for a failover pair
rhienwei2010
I got two ASA firewall units set up as failover pair.  Now I need increase the SSL VPN license, do I need one license for the ASA pair, or two licenses, one for each unit.  Can use one activation key on both units?
One thing I know for sure, put activation key on the Active unit, cannot sync the license to the stand-by unit.
Thanks a lot in advance.
2 Accepted Solutions
Marvin Rhoads
It depends on the version. On ASA 8.3 and later versions, you can share a single license across an HA pair.
Correct. You need to start with Security Plus as your basis for creating a failover pair with the 5505 or 5510 entry level models. Reference.
5 Replies 5
Marvin Rhoads
Thank you very much for the info.
One more thing, I have two 5510s, they are 8.4, but their IOS is K8, doesn't support failover.  I am planing to purchase Security Plus license to upgrade them to support failover.  In this case, can I use one Secrity Plus license to share on two units?  I guess I cannot, becase they are not a pair yet, right?
Regards.
Thank you.  Appreciated.
You're welcome. Thanks for the ratings.
