Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Ascend LAC to Cisco LNS for L2TP
We have set up vpdn via L2TP for our remote dialup customers using a radius profile. Cisco boxes hit the LNS and authenticate the tunnel with no problem. But Ascend MAX boxes fail to authenticate the tunnel. When authentication is turned off for the Ascend LAC and the Cisco LNS it works, but turning off tunnel authentication is not an option for this deployment. It appears that the Cisco LNS is choking on the L2TP tunnel password when it comes over from the Ascend LAC. Anybody know of a solution for this problem? Are these two vendors really THAT far removed from the IETF standard?
1 REPLY
Bronze
Re: Ascend LAC to Cisco LNS for L2TP
First thing I would check is the configs of both the boxes, especially the authenticating strings on both sides. Many times we tend to ignore this very important step to verify if they match. I feel it is hard to answer your question without further information. Can anybody think of something that could go wrong between these two boxes other than the authenticating strings?
180
