ASDM not able to login.
I am able to login through cli but with the same credentials if i access ASDM its saying "Login failed".
Cisco Adaptive Security Appliance Software Version 9.1(5)10
Device Manager Version 7.3(1)
Compiled on Thu 03-Jul-14 09:45 PDT by builders
System image file is "disk0:/asa915-10-smp-k8.bin"
Config file at boot was "startup-config"
ASA up 24 days 2 hours
failover cluster up 36 days 16 hours
Hardware:   ASA5525, 8192 MB RAM, CPU Lynnfield 2393 MHz, 1 CPU (4 cores)
            ASA: 4096 MB RAM, 1 CPU (1 core)
Internal ATA Compact Flash, 8192MB
BIOS Flash MX25L6445E @ 0xffbb0000, 8192KB
Encryption hardware device : Cisco ASA-55xx on-board accelerator (revision 0x1)
                             Boot microcode        : CNPx-MC-BOOT-2.00
                             SSL/IKE microcode     : CNPx-MC-SSL-PLUS-T020
                             IPSec microcode       : CNPx-MC-IPSEC-MAIN-0026
                             Number of accelerators: 1
Baseboard Management Controller (revision 0x1) Firmware Version: 2.4
 0: Int: Internal-Data0/0    : address is 18e7.282e.8a5d, irq 11
 1: Ext: GigabitEthernet0/0  : address is 18e7.282e.8a62, irq 5
 2: Ext: GigabitEthernet0/1  : address is 18e7.282e.8a5e, irq 5
 3: Ext: GigabitEthernet0/2  : address is 18e7.282e.8a63, irq 10
 4: Ext: GigabitEthernet0/3  : address is 18e7.282e.8a5f, irq 10
 5: Ext: GigabitEthernet0/4  : address is 18e7.282e.8a64, irq 5
 6: Ext: GigabitEthernet0/5  : address is 18e7.282e.8a60, irq 5
 7: Ext: GigabitEthernet0/6  : address is 18e7.282e.8a65, irq 10
 8: Ext: GigabitEthernet0/7  : address is 18e7.282e.8a61, irq 10
 9: Ext: GigabitEthernet1/0  : address is 00e0.ed24.35d0, irq 11
10: Ext: GigabitEthernet1/1  : address is 00e0.ed24.35d1, irq 5
11: Ext: GigabitEthernet1/2  : address is 00e0.ed24.35d2, irq 5
12: Ext: GigabitEthernet1/3  : address is 00e0.ed24.35d3, irq 11
13: Ext: GigabitEthernet1/4  : address is 00e0.ed24.35d4, irq 11
14: Ext: GigabitEthernet1/5  : address is 00e0.ed24.35d5, irq 5
15: Int: Internal-Data0/1    : address is 0000.0001.0002, irq 0
16: Int: Internal-Control0/0 : address is 0000.0001.0001, irq 0
17: Int: Internal-Data0/2    : address is 0000.0001.0003, irq 0
18: Ext: Management0/0       : address is 18e7.282e.8a5d, irq 0
Licensed features for this platform:
Maximum Physical Interfaces       : Unlimited      perpetual
Maximum VLANs                     : 200            perpetual
Inside Hosts                      : Unlimited      perpetual
Failover                          : Active/Active  perpetual
Encryption-DES                    : Enabled        perpetual
Encryption-3DES-AES               : Enabled        perpetual
Security Contexts                 : 5              perpetual
GTP/GPRS                          : Disabled       perpetual
AnyConnect Premium Peers          : 10             perpetual
AnyConnect Essentials             : 750            perpetual
Other VPN Peers                   : 750            perpetual
Total VPN Peers                   : 750            perpetual
Shared License                    : Enabled        perpetual
AnyConnect for Mobile             : Enabled        perpetual
AnyConnect for Cisco VPN Phone    : Enabled        perpetual
Advanced Endpoint Assessment      : Disabled       perpetual
UC Phone Proxy Sessions           : 100            perpetual
Total UC Proxy Sessions           : 100            perpetual
Botnet Traffic Filter             : Disabled       perpetual
Intercompany Media Engine         : Enabled        perpetual
IPS Module                        : Disabled       perpetual
Cluster                           : Enabled        perpetual
Cluster Members                   : 2              perpetual
This platform has an ASA5525 VPN Premium license.
Failover cluster licensed features for this platform:
Security Contexts                 : 10             perpetual
AnyConnect Premium Peers          : 20             perpetual
UC Phone Proxy Sessions           : 200            perpetual
Total UC Proxy Sessions           : 200            perpetual
ASA# dir disk0:
Directory of disk0:/
10     drwx  4096         14:56:22 Feb 21 2014  log
21     drwx  4096         09:04:42 Sep 14 2014  crypto_archive
22     drwx  4096         14:56:56 Feb 21 2014  coredumpinfo
103    -rwx  369920       02:58:02 Sep 17 2014  crash.txt
104    -rwx  17851400     15:00:26 Feb 21 2014  asdm-66114.bin
105    -rwx  38191104     03:55:16 Aug 31 2014  asa912-smp-k8.bin
106    -rwx  25088760     06:17:18 Sep 02 2014  asdm-731.bin
107    -rwx  38025216     06:16:26 Sep 02 2014  asa915-10-smp-k8.bin
108    -rwx  35468146     02:14:58 Sep 03 2014  anyconnect-win-3.1.05182-k9.pkg
109    -rwx  11612177     01:50:50 Sep 04 2014  anyconnect-macosx-i386-3.1.05182-k9.pkg
ASA# sh run http
http server enable
http 10.10.10.0 255.255.255.0 management
ASA# sh run ssl
ssl encryption rc4-sha1 aes128-sha1 aes256-sha1 3des-sha1
ASA# sh run asdm
asdm image disk0:/asdm-731.bin
ASA# sh run aaa
aaa authentication ssh console LOCAL
aaa authentication http console LOCAL
My java version is
version 8 update 20
Marvin Rhoads
You may need to register your ASA certificate with Java. Reference this document.
You can export the certificate without using ASDM - use your browser's toolbar after having browsed to the ASA.
10 Replies 10
Marvin Rhoads
Thanks for the input Marvin,Few interesting observations i did try the above method using ASDM like few of the steps below.
  • Export the SSL certificate of your ASA
    • Use a web browser to access the ASA https://YourAsaDevice
    • Export the SSL certificate and save to the file system
      • For example, on Firefox right click on page, View Page Info -> Security -> View Certificate -> Details tab -> Export (will be prompted to save to file system)
  • Import it into the Java Control Panel as a "Secure Site" certificate
    • Run the Java control panel
    • Security tab -> Manage Certificates -> Certificate type: Secure Site -> User tab -> Import
    • Select the saved certificate file from above
But it didnt work initially then later i had to create a new username then it started working.
You're welcome - glad it's now working for you.
Please rate your question as answered if it helped.
Sure Marv,What do you think it worked with new username...
Hard to say but one plausible explanation is that someone changed the password associated with the old username by mistake.
You'd have to compare a working and non-working copy of the config (if you have them) to see if the hashed value for the password was different.
ohh i tried that....iam the only one with access..is something related to max usn/pwd limitations...cos the one which worked was simple cisco usn..
Hmm.
Well as of ASA 8.4(2) they eliminated the ability to use the old "asa" default username. That shouldn't be an issue with your 9.1 though.
Local password policy restrictions became available as of 9.1(2) (and 8.4(4.1)) but that too shouldn't affect you. Beside, the default is not to have such a policy until it's been configured.
I am getting the certificate in PEM format when i download. I will be able to import it to Java control panel only if it is in CSR or .p12 format.
Any suggestions. I am not able to login to the ASDM since a week and now i have to fix it asap. Any help on this is much appreciated.
jpeterson6
Level 2
Level 2
I know this is super old but I didn't find success in creating a new user.
What I ended up doing was changing the http server listening port via CLI; 'http server enable 2002' (for example).
I suspect the issue was/is that Anyconnect is using the same interface via port 443, as was the case with me. As soon as I changed the listening port for ASDM it connected fine.
Fantastic post @jpeterson3.  This workaround solved a recent ASDM access issue following an upgrade.
