Hellocould you please share the solution for showing dropped packet from internet to inside lan ? i have FTD 4100 series managed by fmc I want to see output from cli or fmc related to nat transactions packet(dropped and passed) both.
The content you are looking for has been archived. View related content below.
Hi,FTD was added and to FMC and while configuring HA in FMC, deleted FTD from FMC.While trying to add again to same FMC, both primary and secondary FTD not getting registered in FMC.Could you please help on getting the FTD registered with FMC.
I plan to migrate a FMC running in vsphere to AWS. Initially I plan to: 1. Build the FMC in AWS as brand new; 2. Backup the existing FMC (running v7 already) and then restore the backup in AWS FMC; 3. Login to AWS FMC serial console to change the MGM...
We have FMC and FTD , In FMC we configured Blocked traffic ACCESS POLICY , but while checking in FTD(CLI) one more ACL( Ifc Outside any any allow) showing with same rule-id 26844160. any ideas how to find this ACL in FMCACL in FTD ========access-li...
We received vulnerability mail from my security team. Could you anyone have solution for this vulnerability CVE-2023-51384 , CVE-2023-48795 , CVE-2023-51385
Team,We have a new Cisco Firepower 1120 just configured with basic configuration.After the admin user I added another user with the "configure user add" command.This new user can SSH to the device but cannot SSL.Further, I want to ensure that this ne...
Hi, I'm deploying config from CSM but received error : An error response from the device prevented successful completion of this operation. The device provided the following description: enable password ****** pbkdf2 PBKDF2 hashed enable password ***...
We receive this vulnerability on Cisco C9120AXI-E Access Point, Let me know if anyone has solution for this vulnerabilityCVE ID: CVE-2023-48795https://bst.cisco.com/bugsearch/bug/CSCwi61646?rfs=qvloginhttps://www.tenable.com/plugins/nessus/187315
Hello,We have a cisco asa 5510 Firewall running the latest version 9.1(7)23 connected to our Office through an IPSec VPN Tunnel, and we are trying to configure a new management machine to connect remotly to the management ip address of the firewall, ...
Hi,I have a Cisco FMC 1000 that manages about 20 FTDs.https://www.cisco.com/c/en/us/products/collateral/security/firesight-management-center/eos-eol-notice-c51-742625.htmlIt looks like Cisco soon no longer support it and it will be obsolete in July 3...
I'm trying to authenticate SSH/HTTP with kerberos on ASA 9.18(4)22Not sure if it's a license issue, i don't think so, but i also do not have security plus for this license.Not sure where to configure which protocols to use for kerberosI do have stron...
I only I can have FMC virtual hosted on prem with our KVM based cluster, and it is free! and all the costs would be those purchase of FTD device (FPR1010 or FPR31xx) as well as all the licenses. What would cdFMC be like? Comparing with the two, any m...
I'm trying to figure out how to display user authentication attempts for VPN success/failures. I can see successful logins but not sure where to go to show failed login attempts. I have configured a Flexconfig Object to not hide username. Just trying...
i can see the active tunnel numbers in asdm monitor page or show crypto ipsec stats in cli, but cant find any command to check the details about those 17 tunnels. show crypto isakmp sa ----1 IKE peer show crypto ipsec sa ---ipsec 5 sa show vpn-sessio...
Hi Members, We have 2 infra running in my network,active one is running on Nautanix and standby on VMware. Now we have one FMCV installed in the Nautanix, currently manage the FW via Nautanix FMC, we have installed the same version FMCV in the VMware...
Subject | Author | Posted |
04-15-2024 12:25 PM | ||
04-11-2024 06:53 AM | ||
04-09-2024 12:24 AM | ||
04-04-2024 02:07 PM | ||
04-04-2024 07:29 AM |
User | Count |
8 | |
7 | |
5 | |
4 | |
4 |
