09-19-2017 09:27 AM - edited 02-21-2020 06:19 AM
Hi Experts
I have the FMC VM running on KVM on Ubuntu. I can reach gateway router on the same VLAN, but can not reach the Firepower 9300 cluster interfaces running FTD image. I should be able to add the in band mgmt interfaces to the FMC GUI. The cluster mgmt ports don't ping from anywhere.
Any suggestions?
Sumanta.
Solved! Go to Solution.
09-30-2017 06:21 AM
OK - the in-band management port for the cluster should indeed be accessible by ssh.
I'd recommend you go ahead and open a TAC case and they can dig in interactively with your and find out what's going wrong.
09-19-2017 06:41 PM
Are you able to reach the cluster management interfaces via ssh?
09-20-2017 04:36 AM
09-22-2017 12:12 PM
09-23-2017 07:28 AM
Are you trying to log into the cluster control link address? if so, I don't believe that is supported. That link is for unit-unit use only and is used for data and control traffic among the cluster members
09-29-2017 11:45 PM
09-30-2017 06:21 AM
