Can't connect to webvpn SSL gateway after a couple of minutes
peter_jevos
Hi;
i've installed the SSL gateway with anyconnect client.
Everythink is working fine, many times logged in and working, and after a few minutes the SSL gateway cannot be reached.
No error page, anything, just loading gateway page without result.
When I reinstall entire webvpn it works again and after about 30 minutes tha same problem appears
I dii 5 succesfull attempts.
I'm using 2081 with 12.4(20)T2, no access lists on the gateway interface
So it seems like ip http-secure doesn't response
Anybody knows ?
thanks
pet
Roman Rodichev
Level 7
Level 7
Do you have SSL VPN user licenses installed on your ASA? If not, ASA comes with 2 SSL user licenses. When you connect to SSL VPN using web browser, ASA tends to create a user session for the clientless connection and then another session for the anyconnect connection. Some of the older ASA code releases had a problem where clientless sessions would get stuck on ASA for a long time. If you only have 2 user licenses, you might be running out of licenses. What version of code are you running? You might see better results with 8.0(4) or 8.2(1).
Roman
Thank you fro your answer
I'm not using ASA, but cisco 2801 Software (C2801-ADVSECURITYK9-M), Version 12.4(20)T2.
So there should be predefined 25 user licences ( according to cisco requirements)
However there are no active connections now:
sh webvpn stats detail
User session statistics:
Active user sessions : 0 AAA pending reqs : 0
Peak user sessions : 2 Peak time : 02:14:47
Active user TCP conns : 0 Terminated user sessions : 5
Session alloc failures : 0 Authentication failures : 0
VPN session timeout : 0 VPN idle timeout : 0
User cleared VPN sessions: 1 Exceeded ctx user limit : 0
Exceeded total user limit: 0
Client process rcvd pkts : 885 Server process rcvd pkts : 0
Client process sent pkts : 14257 Server process sent pkts : 0
Client CEF received pkts : 6004 Server CEF received pkts : 0
Client CEF rcv punt pkts : 367 Server CEF rcv punt pkts : 0
Client CEF sent pkts : 0 Server CEF sent pkts : 0
Client CEF sent punt pkts: 0 Server CEF sent punt pkts: 0
SSLVPN appl bufs inuse : 0 SSLVPN eng bufs inuse : 0
Active server TCP conns : 0
But what is really funny that no debug is appearing during the website access
thanks
You are more than likely running into the following bug which was resolved in 12.4(20)T3. You can test the workaround by removing the http-redirect if configured. I would suggest that you upgrade the router to the suggested code.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsx41624
Thank you, i removed the http-redirect and now it works
